Re: charging system farmall m
Posted by John T on September 28, 2011 at 12:21:51 from (173.243.181.15):
In Reply to: charging system farmall m posted by NORMAN MOYER on September 28, 2011 at 10:56:09:
If you now have a 4 terminal (BAT FLD LOAD GEN/ARM) Voltage Regulator IT REGULATES FIELD CURRENT AND YOU NO LONGER USE ANY SORT OF THE OLD LHBD LIGHT SWITCH WIRED TO THE GENNY.
BAT on VR to load (NOT battery/starter) side of ammeter.
LOAD on VR now feeds hot battery voltage up to lights and ignition INSTEAD OF THEM BEING FED OFF THE LOAD SIDE OF AMMETER AS WITH A CUTOUT SYSTEM
FLD ON VR wires to FLD on Genny (NO more wire from FLD on genny up to light switch)
GEN/ARM on VR wires to ARM on genny
The VR needs a good ground to work
Heres my non charging Troubleshooting Procedure
John T
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
