charging system farmall m
Posted by NORMAN MOYER on September 28, 2011 at 10:56:09 from (69.133.114.43):
deleted rotary light switch , hooked direct regulator to amp gauge , to bat. does not show charge . am told with cutout system , i need to place resistor on reg. field terminal and gen. field wire to the resistor thus acting as a cutout.have seen such item in picture stands vertical on field terminal like a pencil . and field wire fastens to it , thus taking the place of the field control of the rotary switch . appreciate any help on this . can not find suitable resistor for this task . THANK YOU
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
