Be sure to check those valves.They MIGHT not be open center??? What loos like a "power beyond"port what you got going from valve to valve here might just be an "out" port.(meaning the only time oil is coming out of it is when you are running a function on the valves.Example:when you activate the"A" work port on the valve,the oil is returning thru the "B" side and thru the "out" port. )
If that IS the case,then any time the hydraulics is on,and NO function is selected,the oil will be going over relief ALL THE TIME inside of the "Lift All"tank causing it to WAY overheat !!!!
Just me looking at the photo of those valves,I am THINKING that is how they are built??? (IDK,I am not there where I can check???)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
