Re: cub still not starting
Posted by gene bender on October 06, 2011 at 12:40:54 from (67.55.227.142):
In Reply to: cub still not starting posted by jeep258goat on October 06, 2011 at 10:45:55:
is it a mag or a dist as you arent in time or it would start. You can remove #1 plug and with sw on and wire to plug with plug laying on head you can put your finger in the hole and turn engine over when you feel compression the plug should fire this will help to see if your are in time i do this all the time as it tells me i do have fire on compression at TDC
