Re: farmall m christmas tree hyd help
Posted by D Slater on October 16, 2011 at 04:36:10 from (184.15.3.93):
In Reply to: farmall m christmas tree hyd help posted by grandpajohn on October 15, 2011 at 22:14:32:
Valve should be setting on top of fill pipe for the liftall pump and reservoir. Liftall 1/2 inch pipe thread opening on right side of tractor should go to C.T.V. opening on other side of C.T.V. operating lever. 2 outlets on rear of valve go to cylinder. With C.T.V. lever centered the liftall lever is pulled all the way back and with original parts there was a lock to keep it back. You may have to tie it or whatever. Now oil is passing through the C.T.V. and back in the fill hole with no pressure. When you operate the C.T.V. with a double acting cylinder. Pressure goes to the hydraulic cylinder from one cylinder hose and returns back through the C.T.V. to reservoir.
