Re: 400 PTO shaft size
Posted by Wardner on August 25, 2000 at 07:04:11 from (63.23.215.127):
In Reply to: 400 PTO shaft size posted by Skeeter on August 25, 2000 at 06:27:23:
I can't see why you need an over-running pto adaptor with IPTO as equipped on a 400. Just step on the foot clutch and the tractor will stop. The flywheel effect implement that is connected to your pto will not drive your tractor.
1 1/8 pto were phased out in the early forties on the larger tractors.
Post A Followup
: Re: Re: 400 PTO shaft size
