Re: Re: 400 PTO shaft size
Posted by Skeeter on August 25, 2000 at 07:14:46 from (131.158.72.46):
In Reply to: Re: 400 PTO shaft size posted by Wardner on August 25, 2000 at 07:04:11:
The mechanic at my local Case/IH dealer told me I should get one for this tractor. This 400 doesn't have a live PTO like my tractor. It has the small lever down by the seat you pull/push up and down. While the tractor does stop when the clutch is pushed in, I have to wait for the implement to quit (slow substantially) turning before I can change gears. He said an over-run clutch work stop this. Is that correct.
Post A Followup
: Re: Re: Re: 400 PTO shaft size
