Re: H Charging system
Posted by glennster on November 03, 2011 at 10:03:14 from (76.217.102.189):
In Reply to: Re: H Charging system posted by janicholson on November 02, 2011 at 21:43:03:
hey jim, a couple years back i had a problem with my h charging, everything tested good on the bench, but when installed on the tractor, the genny would not charge, even grounding the f terminal. if i remember you walked me thru isolating the brushes on the genny with some cardboard strips, and checking for continuity. it turned out the insulation on one of the bolts thru the case of the genny would short out when you tightened the nut up. i tried to find the post , but had no success. do you remember what the test proceedure was??
