Posted by janicholson on November 02, 2011 at 21:43:03 from (96.24.99.126):
In Reply to: H Charging system posted by AL Moyer on November 02, 2011 at 21:27:16:
The full field process in this outline of checks will determine the status of the system. Polarization is important. Doing it is simple and requires a piece of 10 gauge solid house wire to jump from the ARM terminal to the BAT terminal on the regulator. Tractor not running, all things connected. Touch the jump for one second. The coil should be connected such that the wire going to the distributor is connected to the Positive terminal if positive ground. No wires should connect from a field terminal to the 4 position switch. Good luck. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
