Re: single wire alternator
Posted by whig on November 05, 2011 at 16:30:29 from (76.118.14.146):
In Reply to: Re: single wire alternator posted by Mike1972chev on November 05, 2011 at 15:32:22:
Mine runs from the alt. to the amp guage and also added the ground wire. If you have any 6 v lights or anything 6 v you will have to change them over to 12 v or they will burn out.I also changed mine over to - ground instead of + ground.If it shows discharge switch the wires on the amp guage and it will show charge. To check if it is charging just remove one of the battery cables. if it stays running you are all set.
