I left alot of detail out.mine does run through the ammeter before the battery.If it shows discharge while running,you need to reverse the wire on it.(Probably still wired for your 6v Pos ground still????)
ALL lights wiil have to be changed to 12 v.A 12 volt battery,grounded negative.It will not hurt the starter.
DO NOT forget a ballast resistor for the coil.(NAPA part # IC 34)The coil will have to have it's wires reversed,as well.+ will hook to the ballast,the other side of the balast goes to the ignition switch.The negative side of the coil NOW hooks to the points lead out of the distributor.
Did not realize that you were still 6v system.Any more questions,just ask.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
