Re: Re: Re: Help with Farmall C carb
Posted by Rich C on August 28, 2000 at 13:04:32 from (198.56.12.237):
In Reply to: Re: Re: Help with Farmall C carb posted by FC on August 28, 2000 at 12:39:07:
Another reason it may not be getting enough fuel would be because of low vacuum. Check that the valves are set correctly. If they are, check the compression. The valves could be leaking by.
Post A Followup
: Re: Re: Re: Re: Help with Farmall C carb
