Re: Cracked Block
Posted by Livin the Dream on November 10, 2011 at 12:20:52 from (71.214.156.73):
In Reply to: Cracked Block posted by doubleN on November 10, 2011 at 06:04:41:
It's a 1950 Super A, the crack that I've found is almost directly behind the carb...it's horizontal...it's leaking antifreeze, no indication that it's leaking internally in oil and no indication that oil is getting into water or antifreeze.
As far as is it a freeze or not I do not know. Have only had tractor since late June...fellow I got it from said he thought it had a cracked block but wasn't sure....I found busted hose and thought I'd found the issue.
