Re: Re: S-C Farmall Clutch
Posted by Larry on August 28, 2000 at 18:21:23 from (205.188.197.36):
In Reply to: Re: S-C Farmall Clutch posted by Larry Ks on August 28, 2000 at 08:34:42:
Thanks Larry Ks The Throw bearing looks as if it is working Ok.Look like I will be forced to split the tractor. I drove it around again today no luck.Also back off the bolts on the pressure plate thought that might help.What if I tow the tractor with it in gear with the clutch in could this work? Any special instructions I need to know about how to split the S-C?
Post A Followup
: Re: Re: Re: S-C Farmall Clutch
