Re: Farmall 560 hydraulic pump
Posted by pete 23 on November 28, 2011 at 16:41:52 from (74.32.238.142):
In Reply to: Farmall 560 hydraulic pump posted by TWhit on November 28, 2011 at 14:22:33:
First off check to make sure the single to double action setting on each aux hydraulic valve is set correctly. Often the roll pin gets bent or broke and the control will turn too far causing system to stay on demand. Other thing is check the orfice screen in the regulator valve assembly Block with four bolts holding cover on. It is a screwdriver headed screen with orfice. The relief valve is also under there and has a very heavy spring so take out a couple of bolts first and use two longer ones to continue removal. Regulator piston has an o-ring that may be shot also.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
