Posted by Wardner on November 29, 2011 at 23:03:05 from (4.154.238.42):
In Reply to: Hey Wardner posted by Jason the Red on November 29, 2011 at 16:50:55:
Thanks for the pictures.
Not sure what is going on there. I presume the smallest gear is the one that moves under the control of the engagement lever and its axial travel is parallel with the crank centerline.
I suspect that the biggest gear is fixed and meshes with the belt pulley gear. Not sure what the smallest gear meshes with but must be the 4/5th slider. But if that is the case, it seems like it would lock up the transmission.
It would help if we had pictures of it shifted and non-shifted and what it engages. Also a look at the clutch gear to see if it is original to tractor.
Right now I am confused and not able to trace the power flow.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
