Posted by Jason the Red on November 29, 2011 at 16:50:55 from (99.109.191.78):
I remembered you wanted to see some pics of my rotary hoe gearbox that mounted in place of the belt pulley attachment. I pulled it off today, so in the process I flipped it upside down and snapped away! I searched all over for a manufacturer, but could find none. One thing that I did find interesting is that the housing is aluminum. The large gear goes towards the engine and in case it is not obvious in the pictures, the big gear on the side by itself shares a shaft with the biggest gear on the other side.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
