Re: Wiring diagram for 340 Indernational 12 volt conversion
Posted by Janicholson on December 06, 2011 at 09:22:49 from (199.17.6.80):
In Reply to: Wiring diagram for 340 Indernational 12 volt conversion posted by Charles C(MO) on December 06, 2011 at 09:05:44:
We cant help much with an external regulator Alt. Diagrame are much more complex and need Car specific diagrams and the ability to carve out the pieces necessary to make it work. Hot rodders might have info on the methodology.
The wire from the Alt big terminal to the amp gauge must be 10ga. The wire from the amp gauge to the Starter switch/Relay/solenoid, can be 10 gauge with a Fuse link in it of 5 amps more than the alt output. The wires from the regulator to the alt can be 12ga (conservative but not under rated)
The remaining wires can be 14 gauge, but I like 12 gauge to make voltage get to where it is needed. Jim
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
