Super C Engine Help
Posted by equeen on December 11, 2011 at 11:55:46 from (209.102.248.236):
I have an engine that reportedly came out of a Super C whose remains were in the weeds.
The block (354898 R1; date code 9-6-W; no SN) appears not to be cracked or welded. It was seized. I was successful in removing 2 pistons; then 2 pistons with sleeves.
I'm considering new guts for the engine. Here's the best I can measure/determine regarding the engine, pistons and rods:
Block bore: 3.615
Sleeve OD: 3.565
Sleeve ID: 3.175
Piston OD: 3.185 at center of piston; 3.165 at top of piston
Piston PN: 4079 (IH)
Rod PN: 30926 DD X 68
It appears evident to me that some of my measurements are off, no matter how many times I measure.
What makes sense - and what doesn't?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
