Re: Coil, Any one will do?
Posted by ltf in nc on September 02, 2000 at 11:23:15 from (206.228.214.93):
In Reply to: Coil, Any one will do? posted by RookieRed on September 02, 2000 at 07:26:54:
I have had good luck using any known good coil. You must use a ballast resistor. The resistor can be internal or external. The voltage to the points needs to be 5 to 7 volts and the reading is taken with the switch on and the points closed. Post your results
Post A Followup
: Re: Re: Coil, Any one will do?
