Change over Magneto
Posted by Bart on September 06, 2000 at 15:23:39 from (209.91.3.8):
I have a 1944 M with a magneto that has very little spark. It has a cutout or whatever it is called on the generator. Can I install a new wiring harness, the coil set-up and still use the same generator after removing the cutout box attached to it? If the battery is a little low, does this cause the spark to be weak at the coil wire? Thanks for any help.
Post A Followup
: Re: Change over Magneto
