Tire and rim sizes for an M
Posted by Baelee05 on February 09, 2012 at 11:33:24 from (12.192.13.220):
Okay, I need a little help here. A couple of years ago I bought and old M. It needs tires badly. They do hold air for the most part but they are size 12.4x38 which is the same tire that our H has. I want to go to either 13.6x38 or 14.9x38 tires on this tractor. What size rims do I need? I'm not sure of the correct way to measure a rim. From outside lip to outside lip the current rims measure 40". Crossways is a little hard to measure with the tire on but it appears to be between 10" and 11". The rims are in pretty decent shape but I am not going to try to jam bigger tires on too small rims. I will sell the tires and rims to someone with an H or M that cannot afford new tires and rims.
