Re: Farmall M trany/cluch problems
Posted by pete 23 on March 12, 2012 at 17:03:31 from (74.32.238.142):
In Reply to: Farmall M trany/cluch problems posted by Nick Roepke on March 12, 2012 at 10:55:19:
The left brake pedal moves the long shaft going through to the left side of the transmission. It runs very close to the lower transmission rear bearing. Thing is, when you push the clutch pedal in that lower shaft should be stopped. Can you shift it into gear. If that shaft is turning you won't be able to get it in gear. I think you have a couple of problems and may have to do some serious trouble shooting. I could name several possible things but you better do some looking in there first.
