Posted by SB in IN on March 20, 2012 at 17:27:08 from (24.178.48.70):
In Reply to: F30 Front Wheel seal posted by ForeverRed on March 19, 2012 at 13:17:31:
You can put F-30 front wheels on a F-20 with out modification, other than getting your caliper out and measuring for a lip seal. When you put cast F-20 wheels on a F-30 you have to chamfer the inner hub because it will hit the back of the spindle. Then you will have to measure for a seal. If I can find the seal box I will give you the number. I know this because I just did it. There may be other ways to do it but this way worked best. The F-30 bearings do fit the F-20 outer races. SB
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
