Re: Sediment Bowl Improvement
Posted by Mike1972chev on April 04, 2012 at 17:25:29 from (99.57.3.120):
In Reply to: Sediment Bowl Improvement posted by Wardner on April 04, 2012 at 15:30:09:
I would rinse that tank out with diesel a few times.You have it off the tractor I take it???
I took mine off,rinsed it with old diesel,did the muratic acid soak,rinsed with water several times,blew it down,and things are all good these days.
I clean the sediment bowl very little these days.I put all my new fuel in VIA a funnel with a brass screen also.
