Sediment Bowl Improvement
Posted by Wardner on April 04, 2012 at 15:30:09 from (4.154.229.171):
third party image
Decided I needed to use my 504 loader tractor. It's been several years since its last use. Cleaned the carb, filed the points, installed a new battery, and drained water from rear frame.
The sediment bowl was plugged. Removed it and installed the screen. Lots of crap in that tank. This should help. The window screen goes in about 3/4".
Been thinking about blowing out the tank with compressed air. Correct me if I am wrong. I don't think there will be any static electricity discharges because the hose is a non-conductor. My body doesn't fit the same classification but I was thinking long rubber gloves should work.
