IH 184 Carb Problem
Posted by KDougM on April 21, 2012 at 18:50:41 from (50.51.140.237):
I have a 1980 IH 184 Lo Boy. The carb started leaking gas from the bottom of the carb. I took the carb off and apart and cleaned it (with carb cleaner). It still leaks. It leaks from the bottom. I really don't know carbs but the location is leaks seems to be some sort of overflow or drain. What part of the carb is failing? Just looking for an idea of what part to replace instead of replacing the whole thing.
