If the fuel is in plenty supply at the carb inlet fitting, the next issue is to see if it runs just a little longer with some application of choke. Not full choke, but some. If it does it may be the needle and seat in the carb partially plugged up. The fuel tank cap must also have a clean open vent hole. If it does, and the choke makes no difference, see if the coil is hot. If it is, the coil is probably bad. As soon as it stops on its own, Pull the coil wire and hold it near the block with insulated pliers. Crank it to see if there is a nice blue spark, if not the coil is still the suspect. Set the points .020" on the high point of the distributor cam, and see if that helps. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
