Posted by D Slater on June 02, 2012 at 12:43:15 from (184.15.2.205):
In Reply to: Super M live pump posted by CNKS on June 01, 2012 at 19:11:50:
have not had a pesco pump apart recently. If I remember correct the springs keep the pieces that side the gears from getting end play. As the gears or other parts wear they keep it closed up to prevent oil passing the ends. Anything over but slightest bearing to shaft play with parts dry is to much. Pump won't turn free but shouldn't be to hard if lubed. If you already have the seals in all you have to loose by trying it is some hydraulic fluid and maybe a gasket or two. It will probably work but keep a eye on the engine oil level for a time.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
