Re: Tractor Vet - Mounted Corn Picker II
Posted by The tractor vet on June 20, 2012 at 17:00:23 from (76.212.225.132):
In Reply to: Tractor Vet - Mounted Corn Picker II posted by Kirk Affeldt on June 20, 2012 at 10:59:44:
Sorry to say that i do not have any axle mounting brackets left and god only knows where the patterns are now . as they were nothing more then a piece of cardboard for a templet and for the ubolts i had them made at a truck spring shop as needed. I used 8 inch channel iron and built off that for the over the axle mounts with 3/8ths flat strap welded to that along with a piece of angle iron. The 319's were the picker of choice back then and were the easiest to mount , a couple of hours and it was on with two guys.
