Re: Farmall 300 PTO problem?
Posted by D Slater on June 21, 2012 at 06:54:20 from (184.15.43.82):
In Reply to: Farmall 300 PTO problem? posted by Zachary Hoyt on June 21, 2012 at 06:24:21:
Sounds like that could be it or the top PTO drive gear behind the clutch striped. PTO with handle back should turn the engine. If the splines are striped a pressure plate and probably the pto drive shaft with gear needed. Yes a split at engine rear.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
