Re: Transmission to Clutch Shaft Removal - Super M
Posted by Pete_5959 on June 24, 2012 at 12:23:42 from (138.162.128.54):
In Reply to: Transmission to Clutch Shaft Removal - Super M posted by dpoc on June 24, 2012 at 11:58:31:
Dpoc,
What are your referring to when you say transmission shafts? I have my Super M transmission opened up at this time. You can remove the coupler from transmission to clutch through the belly pump access but that is all. If you want to do anything inside you will have to remove the deck plate off of the transmission.
