Transmission to Clutch Shaft Removal - Super M
Posted by dpoc on June 24, 2012 at 11:58:31 from (71.89.126.54):
Hello,
I am trying to remove the transmission shafts from a Super M. I posted a message earlier and now have a pretty good idea on how to remove the belly pump. After the belly pump is removed I was wonder how to remove the transmission shafts from the tractor. I have the differential out and was not planning on splitting the tractor. I noticed when I took the belly pump access cover off there is what appears to be a "coupler" on the shaft that runs from the transmission shaft to the clutch. After the belly pump is removed do I just have to remove the four bolts on the "coupler" and shaft will be removed? After this shaft is removed will I then be able to remove the transmission shafts?
Thanks for any advice!
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
