Re: Broken camshaft gear (crankshaft timing)
Posted by Janicholson on July 08, 2012 at 07:50:37 from (96.24.99.126):
In Reply to: Broken camshaft gear (crankshaft timing) posted by Mark Alayne on July 08, 2012 at 07:40:25:
COmbinations of bad things happen when the gear hub breaks. SOmetimes it strips teeth, sometimes it breaks teeth on the other gears (crank and distributor drive. If you really need to be certain of the problem, pull the valve cover and rotate the engine no more than 10 degrees each way with a socket on the front crankshaft nut. if the valve gera hesitates then moves, or does not move, toast it is. There are only a few thousandths backlash in the gears, and the valve train moves with no real slop with the crank. Jim
