Well if yqa just started the tractor the hyd oil was ambient air temp and it will for awhile TILL everything warms up . Normal temp on the oil is around 150 to 180 Normally but add in extra heat and you may have been way over 200 degrees . Your hitch pump may be getting weak . Now with out flow rating the system on a flow rater at operating temp to check gallons per min. and pressure we are shooten in the dark but a weak pump is my guess . Went thru that on our 706 last year was working just fine when i got off and second shift took over two hours after Dusty was running it it started the i don't want to lift anymore . Next morning i put the flow rater on it and i had 10.5 gpm flow at 2050 lbs for a bit and as the fluid temp started up everything started going down FAST . Put a new 12 gpm pump in it and now it is stayen at the 12 gpm at the 2250 that the relief is .
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
