Re: Spark plugs for Farmall H
Posted by John T on August 06, 2012 at 08:23:57 from (216.249.82.117):
In Reply to: Spark plugs for Farmall H posted by John Fulton on August 06, 2012 at 06:41:05:
Best I can tell the Autolite 386 was close to factory original heat range while 388 is a tad hotter, maybe better if compression is gettin low and she using a little oil or youre using it for light jobs or parades etc. A battery powered coil distributor ignition can tolerate resistor plugs better then a magneto where I prefer 3116 which I believe is a NON resistor plug. However the NON Resistor 3116 would also be okay regardless if distributor or mag so Id try 3116 or 388. A good tune up and good wires also helps regardless what brand plugs you run.
John T
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
