Re: Brass float in Farmall Regular
Posted by rustred on August 13, 2012 at 12:34:02 from (184.151.222.129):
In Reply to: Brass float in Farmall Regular posted by wtk on August 13, 2012 at 11:39:54:
your problem is that you have the main jet closed. thats the big round knob on top of carb. try it at 2 turns out and adjust from there. float level will not give you that problem. turn carb upside down and have a look see to make sure its sitting level. thats the way you do it. with the float 1 or 2 32nds from level wont have much effect on running tractor. but anyway thats why you need the choke out cause its starving, funny it even runs.
