Re: Brass float in Farmall Regular
Posted by wtk on August 13, 2012 at 13:19:52 from (68.68.144.44):
In Reply to: Re: Brass float in Farmall Regular posted by rustred on August 13, 2012 at 12:34:02:
It won't start with the knob turned out. with it screwed down tight it runs and sounds great. you try to even crack that knob from being tight it will pop and die.
Same with moving the choke.
It has power at high speed and low with it set this way and starts good.
