Posted by TMatt on August 16, 2012 at 20:18:32 from (70.59.171.247):
On a C I'm having troubles getting the ring and pinion set right. My problem is, when I tighten down the countershaft nut, it pulls the pinion gear out too far to properly mesh with the bevel gear. I've taken all the shims out and it's still set out too far.
When I took it apart, the countershaft nut was barely finger tight. When I put the nut on like it was, the gear mesh looks real good, until I roll it the other direction and the whole countershaft moves about a 1/8th inch out of the case. The cast cover over the nut was cracked when I took it apart so I wonder if this is how it was before?
Could something be worn down causing this extra slack, or did I miss something?
Am I correct that adding shims behind the countershaft front bearing flange will move the pinion gear out farther from the ring gear?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
