Posted by Jon Hagen on August 31, 2012 at 11:17:20 from (69.26.17.61):
In Reply to: 300 ignition posted by Dave8N in Pa on August 31, 2012 at 10:49:40:
IF the tractor has a SI series Delco alternator, the link below gives a good wiring diagram that works with most gas engine tractors with distributor ignition.
The high charge rate on a SI series Delco can result if the Sense wire (marked #2 on the alt rear case) does not have a good connection to battery voltage. This wire is what tells the alternator what the electrical system voltage is so the alternator can adjust it's output to produce a constant 13.5 -14.5 volts. If the #2 sense wire has a bad connection or is not connected to the battery / electrical system, that will cause the alternator to charge at maximum output all the time.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
