Re: 300 ignition
Posted by Dave8N in Pa on August 31, 2012 at 12:07:42 from (72.9.23.229):
In Reply to: Re: 300 ignition posted by Jon Hagen on August 31, 2012 at 11:17:20:
Jon, thank you. That is a good drawing. Still have a few questions. This tractor has an ignition switch like my pick-up.Start on the switch. Is that the right kind of switch? How does that change the drawing if it's the wrong switch? Should I change the switch if it is the wrong kind of switch?
