Re: 300 starter relay update
Posted by Zachary Hoyt on September 01, 2012 at 11:01:22 from (184.12.70.98):
In Reply to: Re: 300 starter relay update posted by D Slater on September 01, 2012 at 10:45:13:
Thanks, that makes sense. I went out and checked it again and there is 12 volts at the I terminal even with the wire to the coil disconnected from it. I will try reversing the big terminals again so that the hot side is closer to the I terminal and see if that fixes it.
Zach
