Farmall 100 fast hitch
Posted by Blake Terry on September 13, 2012 at 13:25:18 from (66.0.35.76):
I have a 1955 farmall 100 that I just restored about a year ago. Everything is doing fine except the hydraulic lift unit. Without a load it will raise and lower very well and fast. Once you add some weight to it it will raise about 3 or 4 inches and stops. Seems to get worse as it gets hot which sounds like to me once the fluid gets hot that it is leaking by rings or a valve in the unit maybe? Or pump? I don't know much about these systems and was looking for a little input. I have replaced the filter in the lift unit and fluid. Any help would be appreciated!! Thanks
