Re: Rear tire valve core
Posted by old on September 17, 2012 at 21:43:25 from (209.86.226.40):
In Reply to: Rear tire valve core posted by 2farmron on September 17, 2012 at 20:52:46:
Position the valve at the top most part of the circle it runs in as in 12 o'clock. Then slowly take the outer part of it off. It will have the core and the stem. Of course have it jacked up. The core can then be removed or if that does not work you replace the whole core/stem assembly
