dumb cub question, but before i mess it up
Posted by ericlb on September 18, 2012 at 17:32:39 from (12.189.32.37):
fixing to mow a large area [ 15 acres] its just grass, i usually use my ford and brush hog for the job, but because the cub gives a nicer looking cut that the brush hog, [ this is a residential park] i was thinking about using it for the job, now this particular cub, when the radiator is filled up to the neck, will overflow about a quart of water during mowing i usually run it about 4 to 6 hours at a time, i understand it has the thermosiphon cooling system,the question is will it be too much for the little cub to run it 8 to 10 hours a day for around 3 days on this job? i realize im kind of pushing the cubs hp limits, but i dont want to hurt the tractor trying to do a nicer mowing job, the ford runs just fine 2nd question, has anybody added a in hose water pump to one of these, to make the water circulate or is that the totaly wrong idea?
