With an alternator you can almost guarantee your 340 is negative ground (virtually all alternators are neg ground). You can verify by looking closely at the alternator - voltage and ground polarity are usually stamped into the alternator case near the belt tension adjusting ear.
Most likely the smoking wires when you try to crank is a bad (loose or corroded) battery cable connection at the starter solenoid. Recommend cleaning/tightening all battery cable connections and see if the problem goes away. If it does not look for a bad solenoid or a stuck starter.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
