You need to buy good quality fittings. You can buy complete new pipes, as I did, because the originals had been cut off at each end and rubber hose fitted, or just the fittings and olives if the pipe is good. There should be no need to crush the olive down hard. Once fitted, the olive will be difficult to remove from the pipe without damaging it, but you should not need to tighten it excessively as this may result in distorting its shape (making it oval instead of round), distorting the pipe itself, distorting the fitting(s) or stripping the threads in the fittings. I use an 'open ring' or 'c' spanner and tighten the nuts until they just bind firmly. If you go further, the nut will distort and the joint will leak. You can use an open jawed spanner, but it does increase the risk of damaging the nut. Good luck,
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
