Re: Farmall M Hydraulic Pump out put shaft seal
Posted by jim warehime on October 07, 2012 at 17:21:29 from (174.252.100.1):
In Reply to: Farmall M Hydraulic Pump out put shaft seal posted by Peter Hendrickson on October 07, 2012 at 17:12:45:
The drive hub is threaded on not pressed, try using a peice of 1/2 inch square stock or something that size and backing it off. Has worked for me might not hurt to put some heat on it first. Don't worry my first time trying to get one off I used a puller too lol. Jim.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
