ballasted weight?
Posted by JRSutton on October 11, 2012 at 11:23:18 from (75.130.109.233):
Just curious - looking at tractordata web site for the weight of a super a.
lists 2400 lbs
or 3450 ballasted.
Thinking a full set of wheel weights can't be much more than 500 lbs... gas, fluids, etc - anothe.. 20?
What do you suppose they consider ballast?
loaded tires?
Wondering if the term has an actual definition in the tractor world.
