Re: Wiring Diagram for 400 farmall 12v alt conversion
Posted by Roy J. Mantonya on October 22, 2012 at 18:28:31 from (207.155.72.196):
In Reply to: Re: Wiring Diagram for 400 farmall 12v alt conversion posted by Janicholson on October 22, 2012 at 17:28:56:
I started in the middle kinda, put on a new regulator, i don't know as it would make a difference , but it was probably a 6v reg. and replaced the starter, burned it up, replaced gen with 12v alt,rebuilt starter, burned it up, had the starter rebuilt for 12v and now it's out again, I have a new 12v bat., alt., and starter all 12v. I have a new reg. that i'm not sure about, but it seems to still work. same 6v coil, and I've replaced porcelin block. There is a group of wires by the reg. that has a screw joining them together, not sure what thats all about. I have a farmall manual that shows a "diagram" and it just shows components and the connections for 6v. since I evidently am electrically handicapped, I would like to know what wire goes where from stem to stern all components needed, those not needed, and the electrical geanies ph # please. thanks Roy
PS if you sent a 6v dia. it didn't come through.
